Notifier Compatability Query
Gambo
  sparky999 said:
Morley will only work with the system sensor if they are Notifier they can be problematic.
I have tried a couple of Notifier devices and do work but not tried a full loop so hence my reservations on it
Pete
What I want to do if possible is replace a notifier panel with a dimension, retain existing call points (if they work), retain detector bases and replace existing notifier heads with system sensor protocol or m-ias protocol (which is the system sensor head with m-ias protocol). Will this work?
It should work ok but you need to check call points
Peter Robinson
Freelance
M:07889038650
Thanks all, I guess the proof of the pudding ............. . I will post the results if and when we change the system. The client is very keen to change from closed/managed protocol to open. The problem is the short term cost to achieve this compared with the exorbinant fee from an esd just to change the panel.
Therein lise a whole new thread!
Do yourself a favour stick the new panel on the deck , run it up on mains and batts , then extend the loop out of the old panel first and boot it up . Do your testing on this loop , then when you are happy have the old one off the wall.
  • 6 months later...
Put in either an ID2000 or ID3000 Still notifier but will still run all the old devices
Regs
FCE
if you have any probs please PM me and ill assist as much as i can
All comments in this post are my own views and do not necessarily reflect the views of my employer
This is what I do when there is doubt.... :rolleyes:
My Amateur Radio Forum
