Veritas 8
Guest Col
I hope someone can point me in the right direction on this.
Veritas 8 blows the bell fuse (fs2) only when the back up battery is connected.
If i remove the battery, or the battery fuse all works ok. I just wondered if i am over looking something simple, or a possible goosed panel.
The battery will power the panel with no mains, i havent tried the bell on just the battery though. Very strange, any advice would be a great help.
Tia
Sounds as though there may be a fault with the battery.
Have you tried replacing it ?
Guest Guest
Like i said before, the battery will power the panel and there is around 12v on it, could there still be a fault with it?
According to the sticker it was replaced in 98.
Guest Guest
Something else i forgot to add, it only blows the fuse when the alarm goes off. I thought at first it was a faulty bell, but it works fine when powered off the mains.
Guest Adrian
:o 98 its 5 years old whatever you do bin it and get a new one.
even if it shows 12v it can still be faulty. I think you need to do this then get back to us with the result.
Adrian B)
