hpotter Posted August 27, 2008 Posted August 27, 2008 Yes, that's right, but I can't find the correct connectors anywhere to connect the dialler to. PM me your address I'll post one FOC. (assuming ok with TSI)
james.wilson Posted August 27, 2008 Posted August 27, 2008 dont see a problem here. Thanks Hpotter securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
hpotter Posted August 28, 2008 Posted August 28, 2008 dont see a problem here.Thanks Hpotter No probs. In post, be there am.
kuchars22 Posted August 31, 2008 Author Posted August 31, 2008 No probs. In post, be there am. hpotter, thanks I've received Ok, fitted and working! However, Ican only get the PA alarm to dial out (defaulted to PIN 2), when I set off an alarm it doesn't dial me. I have set the option for PIN 3 to do this, and set the dialler to program to dial me but nothing. Also checked the wiring again. Any ieas? Can't check the fire as I don't have any smoke alarms yet.
lawandorder Posted August 31, 2008 Posted August 31, 2008 hpotter, thanks I've received Ok, fitted and working! However, Ican only get the PA alarm to dial out (defaulted to PIN 2), when I set off an alarm it doesn't dial me. I have set the option for PIN 3 to do this, and set the dialler to program to dial me but nothing. Also checked the wiring again. Any ieas? Can't check the fire as I don't have any smoke alarms yet. How are you testing it? Be aware that if you are triggering the alarm by opening a final exit door the dialler will not operate until some time after the internal sounder activates.
Rulland Posted August 31, 2008 Posted August 31, 2008 Most panels have a setting that defers signalling for a set period to reduce false alarms-a PA would probrably signal straight away-check the panels settings. Rich.
kuchars22 Posted September 1, 2008 Author Posted September 1, 2008 How are you testing it?Be aware that if you are triggering the alarm by opening a final exit door the dialler will not operate until some time after the internal sounder activates. Yes, the alarm is triggered by a FE PIR in the hallway, though this is temporary as I haven't installed the front door contact yet. This will be set as the FE, and the hallway PIR as an ER eventually. I did let the entry time elapse, the internal and external sounders went off but no dialling. I'll have another look in the manual to see if there is a delayed singalling for alarm
hpotter Posted September 1, 2008 Posted September 1, 2008 Check cmd 89. Alarm confirmation, default is 2 zones activated within 30mins. (assuming EN panel) change to option 0, 1 zone activated. To prove panel or dialler programming, swap the comms outputs from the panel, ie swap orange & yellow wires over then do a PA test.
kuchars22 Posted September 2, 2008 Author Posted September 2, 2008 Check cmd 89. Alarm confirmation, default is 2 zones activated within 30mins. (assuming EN panel) change to option 0, 1 zone activated.To prove panel or dialler programming, swap the comms outputs from the panel, ie swap orange & yellow wires over then do a PA test. I don't think it's an EN panel, the manual doesn't describe the number of zones or the time period before it sends out a signal to channel or pin 7 (Alarm confirmation). Just says it sends a signal to ch 3 (burg) then ch 7 if another detector goes off. If I switch this on, I presume that I also need to wire this to the dialler to a seperate input and record a seperate announcment. I will try the wiring that you have suggested. Thanks
hpotter Posted September 2, 2008 Posted September 2, 2008 To prove panel or dialler programming, swap the comms outputs from the panel, ie swap orange & yellow wires over then do a PA test. Yes do that test first. TBO the panel comms should by default on UK or EN be set up pretty much how you'd want it in this instance. There is 2ply on fe zones but as soon as panel goes into bells channel 3 should go neg (+ve removed). Check cmd 153, make sure option 03 (intruder) selected. Your right about confirmation, but there is a couple of seconds delay on op3 when confirmation selected. I thought maybe if you were unsetting v quickly not to upset neighbours! Yes, lets prove the panel or dialler first as could be barking up wrong tree.
