Scantronic 9930 - Installer Reset
TiSwAs
Hi, i have a scantronic 9930 alram fitted in my garage with 2 zones, i've moved the control box and i've obviously had to remove the cover to re-locate - |The panel needs an engineers reset - i have the engineers code etc i just need to reset the panel - can anyone help me reset or direct me to an engineers manual?
Thanks
No engineer manuals are give out by this community sorry.
ok i suppose i can apprecaite that given that someone could use them for other purposes - so is there any chance someone would help me remove the service lamp?
I'm on eggshells here.
If you have the eng code:
key in eng code, display says "Installer mode"
Key in 99 tick, display says "checking sys, all ok"
press tick.
(sorry C, delete if inappropriate)
He needs the code and it's not defaulting info so.... um... I dunno, OK, lol!
Says he's got the code, hence my post!
I dunno either.
Where's James, LOL.
Thanks all - yes i have the eng code - it sort of worked display says "Battery Missing" if i'd connected the battery back up it would of reset will do that tomorrow.
Thanks again
Thanks
You dont have a 9930 - Thats just the keypad, the system behind it is likely to be a 9651 or 9751, etc, - for future reference
A nearly retired previous installer !
