Philr Posted August 29, 2008 Posted August 29, 2008 Hi, Can anyone recomend an alarm that can be connected to a couple of hardwired sensors and most importantly has a remote key fob for turning it on and off. Most of the DIY alarms that I've seen only seem to support wireless sensors, or don't have a remote - I'm struggling to find anything that has both. This is only for the garage so don't want to spend a lot of money on it, but equally I want something that will be relaible. I'm currently considering the LS800S from Maplin as this is the only alarm I've been able to find that meets all of the above criteria. http://www.maplin.co.uk/Module.aspx?Module...RM&doy=29m8 - Phil
kka Posted August 30, 2008 Posted August 30, 2008 eurosec cpx i agree with gus Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
FASTCAR Posted August 30, 2008 Posted August 30, 2008 Just get any Accenta / Veritas panel as these have zones that can be programmed as keyswitch , then add a single channel remote switch from Maplin. maplin switch 2 pir kit
lawandorder Posted August 30, 2008 Posted August 30, 2008 Hi,Can anyone recomend an alarm that can be connected to a couple of hardwired sensors and most importantly has a remote key fob for turning it on and off. Most of the DIY alarms that I've seen only seem to support wireless sensors, or don't have a remote - I'm struggling to find anything that has both. This is only for the garage so don't want to spend a lot of money on it, but equally I want something that will be relaible. I'm currently considering the LS800S from Maplin as this is the only alarm I've been able to find that meets all of the above criteria. http://www.maplin.co.uk/Module.aspx?Module...RM&doy=29m8 - Phil Be careful with the Maplin Panel. I only say this because it seems to use Infrared for the remote control as opposed to radio so if you have visions of being able to set/unset the alarm in your garage whilst you are in the house you will be sadly dissapointed. With infrared you will need line of sight from the keyfob to the panel/keypad.
Alarm Protection Posted August 30, 2008 Posted August 30, 2008 Im sure Gardtec do a wireless add on device that can be added to any panel that supports wirless keyfobs. !
Adi Posted August 30, 2008 Posted August 30, 2008 Im sure Gardtec do a wireless add on device that can be added to any panel that supports wirless keyfobs. Yes mate, its ungraded but will be ok for this chap. I really can't be ar**** with it anymore.
