Modern Alarms Series 3000/scantronic 9100
SIMONADT
Dudes
Had a callout to a series 3000 and the call engineer light was flashing with no fault on the display. got it into engineers, checked the fuses, power, battery etc etc, 99'd it but still it says call engineer. any ideas? :hmm:
had the same in the past but it came up with either a zone or a specific fault.
cheers
si
Fire and Security Service Engineer
***Any views or statements above are not the views of my Employer***
customer wont pay... even on a service day works
Check to see whether any of the ccts are on test. The call eng light flashes if the cct has failed
The last time someone was there was Feb this year for an RI... nothing is on test.
Unlike modern day panels when you put a cct on test on a 9100 they stayed on test until they were removed via the programming and not after a certain amount of days. Ccts on test will still show up as normal on a walk test.
nice one, i'll try that tomorrow then.
The log doesnt work, it beeps to say end of list all the time!!!
Doesn't the 9100 do that on a panel lid tamper?
try 99 with the tamper spring held down, those lids can be buggers to get on.
it seemed to be locating the tamper when closing it but will try that too!!!
can the lid t be linked out like Galaxy? Is the spring on a circuit with points anywhere?
