whibbs Posted September 1, 2008 Posted September 1, 2008 can any one help i have set up a premier 48 panel i have been using is for a round a year. have just connected a 8hom speaker to it, i can not get the speaker to work when the panel is in exit or entry mode, it only works for the alarm is in active inturder alarm. what can o do to get this to work thanks Wayne Hibbs
Rulland Posted September 1, 2008 Posted September 1, 2008 With the premier range you have to enable speaker tones you wish to hear-from the panel output, from the keypad outputs, and from any expanders-this fooled me for a while when first working on premiers-check the programming for tones you want. Where have you connected the speaker too ?. Richard.
whibbs Posted September 1, 2008 Author Posted September 1, 2008 Direct to the control panel Wayne Hibbs
Rulland Posted September 1, 2008 Posted September 1, 2008 So how did you hear entry/exit tones before? just the keypads internal speaker. Richard.
whibbs Posted September 1, 2008 Author Posted September 1, 2008 Yes just the keypad speaker Wayne Hibbs
Rulland Posted September 1, 2008 Posted September 1, 2008 Ok, I can guarantee that you need to enable certain speaker sounds from the panel output-been there, done that, . It's a programming issue, I assume that if you installed it you have the engineering info ?. Alarm tones are always at full volume-so maybe you need to adjust volumes if you can hear them but nothing else. Rich.
whibbs Posted September 1, 2008 Author Posted September 1, 2008 Ok thanks will take a look at the programing I've got wintex so its easy Thanks Wayne Hibbs
Rulland Posted September 1, 2008 Posted September 1, 2008 The Premier range is highly versatile-and thus needs to be treated with caution if you have any doubts as far as the programming goes-just a gentle reminder from a so called pro Regards. Richard. The Premier range is highly versatile-and thus needs to be treated with caution if you have any doubts as far as the programming goes-just a gentle reminder from a so called pro Check the speaker volumes and what sounds should be annunciated-Wintex makes it easier though. Regards. Richard.
