Pelco Coaxitron Fixed Speed Receiver
lowlofe
I know the DS2 can output Pelco coax control, but thats as far as my knowledge goes.
you would be better using 485 data line on the DM, down the coax dosen't always work best on the DM unit unless the domes are pretty near to DVR
Chris
Trade Member
  • 4 months later...
Can a Pelco Coaxitron Fixed Speed Receiver be controlled by a dedicated micros digital sprite 2?
Regs
Alex
No Coaxitron is pelco's own form of cox controll and what you have is a coaxitron reciever only pelco kit can controll it so long as it has coaxitron in it. The Genex multiplexer dose it if that helps. The DS2 outputs Pelco P and D which is compleatly different to Coaxitron.
Hope this helps best regards Sam.
