endo Posted September 3, 2008 Posted September 3, 2008 Hi I have a veritas r8 plus 2 years old installed by a reputable firm in my flat. During a power cut the alarm sounded internally and externally. The tenant called the installer who told them how to disconnect the battery in the outside unit and the inside panel and pull the mains fuse. It has been left like that for over 6 months totally deactivated. I found this out at the point of tenant moving out So I've reconnected the internal battery and external battery, powered up and the system comes up and beeps continually then after a few minutes the alarm sounds, the panel ignores the user reset code. Any ideas on the correct process to follow to bring it online ? nigel
Rulland Posted September 3, 2008 Posted September 3, 2008 Have you tried the (read rule 12.4),if its bleeping 10 times it's a mains problem or battery volts low,9 times and its bell or panel or global tamper.1-8 times is a zone fault-I would say it's prob 10 times due to it being offline for 6 months. Richard.
endo Posted September 3, 2008 Author Posted September 3, 2008 Have you tried the (read rule 12.4),if its bleeping 10 times it's a mains problem or battery volts low,9 times and its bell or panel or global tamper.1-8 times is a zone fault-I would say it's prob 10 times due to it being offline for 6 months.Richard. thanks very much, I'll be mostly counting those beeps tonight (engineer booked for later in the week just in case)
camerabloke Posted September 3, 2008 Posted September 3, 2008 As im no longer a mod, i will shout NO DEFAULTING INFO Eucam Security Systems 0845 4630 746 www.eucam.co.uk
Guest anguscanplay Posted September 3, 2008 Posted September 3, 2008 As im no longer a mod, i will shoutNO DEFAULTING INFO you must be seeing posts that I can`t ...........
camerabloke Posted September 3, 2008 Posted September 3, 2008 its been edited now Gus Eucam Security Systems 0845 4630 746 www.eucam.co.uk
Chorlton Posted September 3, 2008 Posted September 3, 2008 As im no longer a mod, i will shoutNO DEFAULTING INFO thank you cb, now sorted
Guest anguscanplay Posted September 3, 2008 Posted September 3, 2008 thank you cb, now sorted you`ll have to look in the user manual now instead -
camerabloke Posted September 3, 2008 Posted September 3, 2008 leave your handbag at the office Gus? Eucam Security Systems 0845 4630 746 www.eucam.co.uk
Guest anguscanplay Posted September 3, 2008 Posted September 3, 2008 leave your handbag at the office Gus? sing after me "I`m a little tea pot ........... and your a black kettle" lol user info I tell you, user info
