Galaxy Error Message
sdcbmthsch
Ah - I see; no, it's wired OK - the reason it activated was because I tested it by disconnecting the phone line. I heard the relay click, saw the message appear on the displays, and then reconnected the phone line. The relay clicked back, the message disappeared, but this "residue" alert message insists on remaining when trying to set the alarm!
Thanks
Stephen
have you tried to defeat the zone by use of one resistor(i.e make the circuit healthy) as could be a duff panel??? :sign:
ok whats in the log?
dont you have to clear the log for a fault message ???
07475071344
have you tried doing a soft reset (in parameters )
if is is glitch that should clear it - then repeat the line removal experiment to see if it does it again -
is so or beyond that try ringing galaxy tec (albeit you might be on 'hold' for a while) and get them to advise / talk you through it.
paul
THE BLACK KNIGHT
Thanks for the suggestions; I shall try these out!
Regards
Stephen
paul
Hi, yes the problem has now gone away thanks to a warm reboot. On a related note, the memory backup switch on the main board of the Galaxy appears to be "open" - e.g. it looks like it will dump the programming if all power is lost. According to the manual, it should keep the contents, so is the default position for this switch open? It's an odd looking link - I was expecting a jumper or dipswitch, but it's a small blue plastic thing with what looks like a springy lever which may clip under the other terminal - if I'm seeing it correctly! I don't fancy fiddling with it if it's correct, but if anyone has any thoughts, I'd be most grateful!
Thanks to you all for your help so far.
Stephen
Did you get it sorted out?
Stephen
Yes you must make sure the nvm link is closed otherwise you will lose all programming if power is lost to the system.
Thanks - this, I take it, means that I have to loop the "arm" under the "hook" part? I can then leave it like that? Sorry if this is an obvious question; it's the first time I've seen such a switch!
Stephen
