Minerva Problem
esp-protocol
ADT Minerva panel.
Addresssable sounder started playing up recently, showing high ident.
When removed the panel showed low ident.
If a different device is removed it shows device removed.
Any ideas why it shows low ident when this sounder is removed ??
Thanks
ADT Minerva panel.
Thanks
Another device with the same address?
My Amateur Radio Forum
No double address on minerva, the device current gets added together(hence high then low ident), you are lucky that it is a sounder so didn't generate a fire alarm.
hmm... live and learn...!
seems strange the systems been in for nearly 10 years and its only just come up... i guess the second device is the one drawing a bit more current, hence the problem.... will look into it a bit more....
thanks
