High Speed Mfd ...suggestions?
james.wilson
We need to replace our photocopier. Its currently an A4 ollivetta copia 9910, we also have a networks clp-600 colour laser, 2 x samsung ml-3560 and 1 x minolta 4410.
I need a low cost per mono page (colour less important) MFD ideally A3, but probably A4 (due to budget) >20 ppm, networked for printing and scanning, with a built in fax. (i want to replace as much as possible in one go seen as we rarely manually fax now and the konica unit we have is huge).
SO any suggestions people.
ta
James
  • 2 weeks later...
Do you want to buy or get something on a service contract?, I work for one of the largest copier suppliers in the uk/europe, I can give you advice on what to go for if you need it. PM/Msn no problem if you want to discuss in detail.
Not too bad, can prove expensive on consumables though as they are mono component toner/intergrated drum. samsung fairly new to MFP stuff but knocking out some good kit, too early to tell if they are going to be reliable but a lot of the technology seems to have come from HP.
Give us a shout if you need supplies.
