ddma Posted September 12, 2008 Posted September 12, 2008 How do I connect Odyssey 1E bell to Accenta 8 Mini Would someone please confirm that I have got this correct; Accenta 8 mini panel Odyssey 1E bellbox D > A B > B T > C A > D -ve Strobe > Strobe I'm sure I've got it right but just can't get the box to sound in any mode, please help as its driving me mad. Is there a chance a fuse has blown in the panel ?
lawandorder Posted September 12, 2008 Posted September 12, 2008 How do I connect Odyssey 1E bell to Accenta 8 Mini Would someone please confirm that I have got this correct; Accenta 8 mini panel Odyssey 1E bellbox D > A B > B T > C A > D -ve Strobe > Strobe I'm sure I've got it right but just can't get the box to sound in any mode, please help as its driving me mad. Is there a chance a fuse has blown in the panel ? A should go to A and D should go to D A should go to A and D should go to D Sorry, my mistake, I have just checked the respective manuals and you do actually have it connected correctly. You should have 12 volts across A and D at the panel and in the siren housing, if there is no 12 volts at panel check fuse, if there is 12 volts at panel but not at the sounder check cable.
ddma Posted September 13, 2008 Author Posted September 13, 2008 A should go to A and D should go to DSorry, my mistake, I have just checked the respective manuals and you do actually have it connected correctly. You should have 12 volts across A and D at the panel and in the siren housing, if there is no 12 volts at panel check fuse, if there is 12 volts at panel but not at the sounder check cable. Thanks very much lawandorder. I will go and check fuse now. What caught me out was the fact that 12v is reaching all bell box connections but have I forgotten that one is volt free or something ? I will let you know.
