9448 Manual Needed
happyone
Hi. I have just moved into a house with 9448 console. But I cant figuer out how to switch the alarm on at night so that the sensors downstairs are still on and the upstairs one stays off.
An engineer came round, he said to press '2' (Part) and then enter the code. This did not work.
I've read about how Omit etc - but how?
Any advice or a manual would be greatly appreciated!
Guest anguscanplay
press 2 or 3 (depending on which zone you want to omit) then omit then code
Guest anguscanplay
funny you should say that - dont know what the zones are!
see the button that says "walk test"
walk test - enter - code
the lights will light up as you trigger each detector
when your finished enter your code again to stop the walk test
