Galaxy 8 Problem
TheGovernor
Huh, well I've been through the logs and there's nothing I can see that explains the blip.
I'm half tempted to the ladder out and just disconnect the sirens and everything and replace it...
I may be drowning without hope of rescue here :)
I looked through the system and noticed there are 3 keypads listed in the diagnostics, although I onyl have 2 keypads (one upstairs, one downstairs).
The third keypad is listed as number 15 and has 0% connectivity, would anyone know why you'd have a 3rd keypad in the diagnostics that isn't listed anywhere else?
I'm also wondering if it was caused by some sort of battery problem as there are a few "CU+/-" battery errors listed in the log (they could also be from when I was trying to sort it out too so that isn't conclusive.
The battery is brand new, fitted only a couple fo months ago... but you never know.
I suspect it might be a PCB problem, mostly because a power reset resolved it for now, I'm a computer network techie originally and it definitely feels like an electronics problem.
Nothing in the programming manual provides any guidance for this sort of problem.
