June 17, 200421 yr comment_15705 Also turn on options 3.2 and 3.3 The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/2477-double-pole/page/2/#findComment-15705 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 18, 200421 yr comment_15727 nikki It should and will work with both the resistors in the detector.Make sure your 2 wires are correct at the panel and the detector (The same colour)If it works fine with one in the panel it will work with both of them in the detector. Houston Security Systems Ltd Intruder alarms CCTV Door entry Fire protection Networking SSAIB Approved Link to comment https://www.thesecurityinstaller.co.uk/community/topic/2477-double-pole/page/2/#findComment-15727 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
