mapleford Posted September 19, 2008 Posted September 19, 2008 Hi all, Got a call today to look at the above as it had a fault showing, arrived on site and the panel is beeping away, zone lights and general fault flashing away, if I disable all the zones the fault can be cleared but liven up any of the zones and the fault's back (only zones 1+2 are in use). I'm guessing the panel's dead unless anyone has any ideas? When I got there the front was off the panel, in the bottom of the panel were 4 resistors, Do you know if a couple of these should be in the unused zones, tried putting them in and it seemed to have no effect, but didn't try disabling the in use zones. Did try putting the resistors in all the zones with the wires for zones 1+2 disconnected still the fault persisted.
Alarm Protection Posted September 19, 2008 Posted September 19, 2008 Dont know this panel but how did you disable all the zones in the first place to clear the faults?? !
mapleford Posted September 19, 2008 Author Posted September 19, 2008 Dont know this panel but how did you disable all the zones in the first place to clear the faults?? Panel allows you to disable individual zones, basically turn them off, so just turned them of one by one till they were all off.
