Texecom Pir Fault
stdspeed
Hi Guys, been lurking on here for a few months now and now finally found the time to install a Texecom Prem 48 system.
All went well apart from an embarrasing self inflicted wiring error, but.....
I programmed the panel using Wintex. Zone 2 is a guard/access PIR. Under diagnostics all appears to be well and I carried out a succesful walk test.
Then I noticed a detector test button which I clicked on and 60 secs later it reported a 'fault' for zone 2.
The only way I've found to clear the fault it to factory reset, and so long as I dont test the system again it all works fine.
I did try changing the PIR and that made no difference.
Is 'fault' in this case a general wiring fault ? Any other ideas ?
worried about an intermittent fault occuring now. :whistle:
Thanks in advance for any help. Off to bed now will try again with a fresh head in the am.
ATB
What Pirs have you used?
They don't have a test terminal do they?
IIRC Test is for grade 3 Anti Mask detectors.
No they don't have a test terminal.
I'm surprised only one detector is showing a fault, however it simply resets from Wintex now.
If you think its only for anti mask detectors I'll ignore it. Everything else appears to work fine.
Thx
