BARA Posted September 21, 2008 Author Posted September 21, 2008 Ye, I know thank. Just trying to get a it more of an insight into it. WHAT VALUE OF RESISTOR. Is it a different value for the PIR, MICRO, MASKING AND TAMPER? or does the tamper not need an eol when using the TEOL wiring method?
Guest anguscanplay Posted September 21, 2008 Posted September 21, 2008 BARA said: Ye, I know thank. Just trying to get a it more of an insight into it.WHAT VALUE OF RESISTOR. Is it a different value for the PIR, MICRO, MASKING AND TAMPER? or does the tamper not need an eol when using the TEOL wiring method? dog ran off ............ do you not have the manual?
antinode Posted September 21, 2008 Posted September 21, 2008 Never wired a detector FSL before? 4K7 in parallel with the alarm contacts, 2K2 between one of the tamper contacts and one of the alarm contacts, another 2K2 in paralell with the mask contacts with a link from one side of the mask contacts to the unpopulated side of the tamper contacts. Your zone wiring goes across the alarm contact terminal with just one resistor leg in it and the mask terminal with just one resistor leg in it. anguscanplay said: dog ran off ............ do you not have the manual? And the grass? Trade Member
BARA Posted September 21, 2008 Author Posted September 21, 2008 5000+ posts and you cant just give an answer. says alot! No, no manual. Thought thats what these forums were for. maybe not
Chorlton Posted September 21, 2008 Posted September 21, 2008 BARA said: 5000+ posts and you cant just give an answer. says alot! No, no manual. Thought thats what these forums were for. maybe not C.
