Gardtec 300/500 Series
barry1962
Hello all can someone help please, i have a guardtec 300/500 series and i cannot get it to set, when i enter the code and press set i get this message C6
i have the user manual and this C6 is not showing in there, i have done a system rest and the siren sounds, but i cannot get the alarm to set .
I used to have a 5 year annuual mainteance contract on the alarm but the company is no longer in business, heres hoping someone can help.
THANKS BARRY
THANKS BARRY
hi barry,
C6 = Circuit 6,
so whatever is connected to C6 like perhaps a door, it is not closed, or a detector has developed a fault.
have you changed any doors? if so you needed to refit the magnet to the new dooror perhaps panic button was pressed and needs re-seting.
your installer should have listed the zones in the back of your user manual
regs
alan
Guest anguscanplay
C6? or Cb?
I`d suspect the lids off the control unit
Cb means control panel tamper or keypad PIN tamper (the latter meaning someone entering the wrong code too many times)
Check to make sure the lid on the main control panel is secure and hasn't been knocked. Then try entering your code and press YES and enter your code again to reset.
Trade Member
Guest anguscanplay
Ct is keypad tamper ..............
Ct is keypad lid tamper IIRC, Cb could also mean key press tamper according to the blurb.
Trade Member
Guest anguscanplay
its rt for excess keys LOL.
  arfur mo said:
hi barry,
C6 = Circuit 6,
regs
alan
Hi alan thanks for the info, by the way message does read Cb and not C6 SO MY APPOLOGIES to everyone, there are magnet door connectors and yes i have had a new door fitted last year, but sure it worked after new door was fitted, but i could be wrong as i've not used the alarm for ages.
I did take the cover off control box just to put another battery in which i think explains the cb, i will try setting it again tomorrow as it's late for the siren to be blaring out now, my neighbours won't be impressed (LOL) once again thanks for your help i will repost tomorrow to let everyone know how i go on.
BARRY
Guest anguscanplay
BARRY
shrugs shoulders in disbelief
for future information - the panel only shows the circuit number 1,2,3,etc not C 1,2,3 etc if it`s a zone in fault
but hey - what do I know
  anguscanplay said:
C6? or Cb?
Sorry i meant CB i did remove cover of control panel to fit a new battery, but it is now securely back in place, i will try set again tomorrow and repost on how i get on, thanks for your help
BARRY
