gersrt Posted September 22, 2008 Posted September 22, 2008 HI I've just installed an aritech cs450 control panel to replace my burnt out cs350. Everything is working ok, but I need a bit of help with 2 things. I need to conect the old pir from the cs350. On the cs 350 control panel there was a dedicated input for a pir, but on the new cs450 there doesn't seem to be. I tried just connecting it into one of the spare zones but it is not flashing away (powering up). Any Ideas. Also my Zones are like this zone 1 Front door zone 2 upstairs zone 3 back door and downstairs windows zone 5 Panic. Can someone give me a detailed method for setting up the part arm on the control panel, to have Zone 1 and Zone 3 only arm when going to bed, because the manual is a little confussing. Thanks
arfur mo Posted September 22, 2008 Posted September 22, 2008 HI I've just installed an aritech cs450 control panel to replace my burnt out cs350.Everything is working ok, but I need a bit of help with 2 things. I need to conect the old pir from the cs350. On the cs 350 control panel there was a dedicated input for a pir, but on the new cs450 there doesn't seem to be. I tried just connecting it into one of the spare zones but it is not flashing away (powering up). Any Ideas. Also my Zones are like this zone 1 Front door zone 2 upstairs zone 3 back door and downstairs windows zone 5 Panic. Can someone give me a detailed method for setting up the part arm on the control panel, to have Zone 1 and Zone 3 only arm when going to bed, because the manual is a little confussing. Thanks i can't say i know this Aritec panel, but you should have had installation instructions in the box to refere to, if not get the vedor to send them. generally the pir/s will be powered from 2 terminals usually marked AUX or Auxillary, connect a meter on DC volts to see if 12 volts is beening output from you panel, if not then likely a fuse has blown on the main PCB, not serious but will need replacing and proper testing for any short circuits prior to fitting a new fuse. regs alan If you think education is difficult, try being stupid!!!!
