9448+ Control Panel is Dead?
Guest liamliddy
Guest liamliddy
Following a powercut, my Scantronic 9448+ control panel is non-responsive and not working at all. I noticed one of the sensors was making a slight buzzing noise everytime it detected movement after the powercut, then also noticed the control panel was not working at all, no lights, nothing. Checked electric supply into the panel and all is as it should be.
Does anyone know what it could be?
cheers and thanks in advance
Liam
If the panel is completely dead then the detectors shouldn't be doing anything.
Check the battery and then the fuses.
BE CAREFULL THERE IS MAINS POWER IN THE PANEL if you are anyway unsure at all get a local company to come in and repair it.
Colin.
The Back up battery in the control panel is duff, replace it and all should be well.
do make sure that the charging circuit is checked first though as duff batts have a habit of destroying the charging circuit.
If you decide to do this work yourself, do be aware that there are mains voltages inside the panel that can kill, so do be carefull.
hope this helps
Regards
Bellman
Hi Colin,
You beat me to it again :huh:
I'll have to learn to type faster !
Regards
Bellman
Lol, but you have to wear a skirt and hi heels then :lol:
woh scary thought :P
I'd not be much good up a ladder in that get up though would I, (think of the nasty sight the apprentice would get whilst footing my ladders ) :D:D
I think i'll leave the skirt wearing up to you scotts in kilts....
Regards
Bellman
P.S. does your sporran get caught on the ladders? :unsure:
Regards
Bellman
I didn't think you service boys new what ladders were for :lol:
Its not my sporran that i have to worry about ;)
Colin.
OH Colin..............the thought of you up a ladder!
!!!!!!!!!!!!!!!!!!!!lol!!!!!!!!!!!!!!!!!!!!!
:D
Steve Kendall
Plymstock Security Systems
Hi Colin,
It's not that I would normaly have to use them. (decorative effect only) it's just the fact that i've got to find SOMETHING the apprentice is good at :D
Regards
Bellman
Hi Colin,
Regards
Bellman
When are ADT processing the apprentice applications?
Haven't heard owt yet :(
Warren
Red Fox | Hosting
Affordable and Reliable UK Based Web Hosting
