davetherave69 Posted September 26, 2008 Posted September 26, 2008 Hi Installed a prem 24 today with wirles network receiver and 6 pirs and 1 door contact which are all wireless all works fine apart from zone 7 its been programed into the paniel correct and signal is 90 when you take the cover of it displays a tamper on zone 7 which is correct but it will not show up on a walk test or triger the alarm it has driven me made fought findind on it didnt get in t0 8pm and will have to go back on Monday this is the first wirless system we have done, client didnt want us to lift up the carpits any help would be grat thans in advance
Guest anguscanplay Posted September 26, 2008 Posted September 26, 2008 might as well get the insults out of the way first - you did allow for the units sleep time ?
davetherave69 Posted September 26, 2008 Author Posted September 26, 2008 might as well get the insults out of the way first - you did allow for the units sleep time ? All over sesors worked fine first time I didnt no anything about sleep time could you tell me more the sensors were powered up at 1pm and still not working prop by 6pm
Guest anguscanplay Posted September 26, 2008 Posted September 26, 2008 All over sesors worked fine first time I didnt no anything about sleep time could you tell me more the sensors were powered up at 1pm and still not working prop by 6pm usually a radio PIR will "go to sleep" after an activation for somewhere between 90 and 180 seconds to save the battery, many, many times I`ve waited till i think its ready only to find its still asleep and then starts timing all over again. it should have an over ride link so you can walk test (old scantronic ones used to go live for 5 mins after a tamper)
james.wilson Posted September 26, 2008 Posted September 26, 2008 yep you need to clear the room for 3-5 mins any activity will extend the sleep timer. You can usually bypass this for testing purposed with a jumper etc in the sensor securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
NitroN Posted September 28, 2008 Posted September 28, 2008 Hi, 1. I don't want to be insulting, but I have often seen wireless PIR's installed upside down... Please check this! 2. a. Unless the wireless detectors are bi-directional, of which very few currently are, the detector does not know if the panel is armed or not. This means that the detector has to transmit every signal to the panel. Picture the wireless PIR in a busy area, ICU, ICU, ICU, ICU, etc. This would kill the PIR's battery life in a short time. b. To extend a wireless PIR's battery life a "sleep period" was introduced. This means that a wireless PIR will transmit the first signal, but will wait for a period of no activity, before it will transmit a second signal. This time differs between different manufacturers. c. Does this reduce the installations effective security? No, as a signal has already been sent to the panel, which, if it is armed, would have created an alarm. d. Normally this is only noticed by an installer walk-testing the system. "Sleep time" normally only applies to wireless PIR's and not other wireless detectors like wireless magnetic contacts, etc. Regards NitroN
Alarm Co Posted September 28, 2008 Posted September 28, 2008 yes and you wait till you gotta explain that one to the customer , that it dont detect nothin for five mins,??? omg 'so if someone hiding around the corner and they watch me leave they have five mins to enter my property'
davetherave69 Posted September 28, 2008 Author Posted September 28, 2008 yes and you wait till you gotta explain that one to the customer , that it dont detect nothin for five mins,???omg 'so if someone hiding around the corner and they watch me leave they have five mins to enter my property' Ok thanks for you help Ihope 2 get it sorted when i go there 2 morow
