September 26, 200818 yr comment_211762 i installed a security system from cpcam when i hooked up the antenna form the wireless camera don't know what to do and the company does help much Link to comment https://www.thesecurityinstaller.co.uk/community/topic/24887-need-help-hooking-up-a-wireless-camera/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 26, 200818 yr comment_211764 we will probably need a bit more info, like what you have, what you have done, what works and what doesnt. James securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/24887-need-help-hooking-up-a-wireless-camera/#findComment-211764 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
October 6, 200818 yr comment_212613 First you will take a receiver and you will need to make sure that it is on the same "channel" as the camera. Look at the camera. There should be a sticker or something that says 1, or 2, or 3, or 4. If it has a punch through the number, or a check mark on it then that is the channel that you will set the receiver too. If you cannot tell what channel the camera is on then put the camera next to the receiver, and go through the channels until you see the video. The yellow connector (USA composite) is the video out. Connect an RCA cable to the yellow connector. On the other end you will have to get an RCA to BNC adapter. The adapter goes on the DVR camera input, and the RCA cable plugs in to the adapter. Note: Some receivers will lose the channel setting when the power goes out, and you will have to manually reset the channel back to the one that you need to make it operate. You may want to have it on a battery back up to avoid short term power loss situations. Note: In the USA the 2.4 GHz frequency is the same frequency used with wireless internet 802.11. You may have to change the wireless router to a different "channel" to avoid interference. Note: The distance on the package of a wireless cam is for direct line of sight from receiver, and the camera antenna. In other words if you penetrate a wall with the receiver on one side, and the camera on the other then you will have to move them closer together in order to keep the energy level up so that the receiver can see the camera video. I cut the package distance in half when selecting a camera. If it says 300 feet (USA) then use it only for 150 feet. If you need 400 feet for your project then you will want to select a wireless camera that has 1000 feet line of sight. The more walls that you penetrate then the closer you will have to get the camera, and the receiver to make it work. Here is a trick. Put the receiver on the most outer wall, and run wiring back to the DVR. The outside camera will give the receiver the best signal, and make your system trouble free. In the USA the highest wattage that you can use without a license is one watt. If you go over one watt then you are in violation of FCC Rules, or you need to get a license to operate that "radio". You can use low wattage systems with no problems. Use directional antennas that point at each other to give you direct line of sight, and you get a better signal output compared to an omnidirectional antennas. Also raise the the antennas over tree tops, and rooflines to get a better reception. What do you think?? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/24887-need-help-hooking-up-a-wireless-camera/#findComment-212613 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
