Alarm Co Posted September 28, 2008 Posted September 28, 2008 was workin on someones install yesterday sparkys had installed two plots with texecom prem 24s but wld programme it so i progd alarm and tested ok then powerd up expander and then walk tested zones on that ok but when i tried leaving eng kept saying aux tamp? cldnt find any fault when i removed lid from exp it also came up exp tamp?,, when i removed global tamp it cam up 0aux tamp,, bell tamp , keypad tamp etc etc ,, but cld not find aux tamp , every tamper i cld find was working , so wot is aux tamp ?
1019641 Posted September 28, 2008 Posted September 28, 2008 As were in public, Aux tamper is located in the main control panel, left on zone 1 Also on each expander bottom left terminals you know what to do Dean Wholey NCC Dean.Wholey@Ntlworld.com
breff Posted September 28, 2008 Posted September 28, 2008 You may find the expander input is progged as aux tamper. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Adi Posted September 28, 2008 Posted September 28, 2008 got to link it out. I really can't be ar**** with it anymore.
Alarm Co Posted September 28, 2008 Author Posted September 28, 2008 As were in public, Aux tamper is located in the main control panel, left on zone 1 Also on each expander bottom left terminals you know what to do when you open this , the key pad shows 0aux tamp aswell as aux tamp so its not the one on the main board
