Recommendations For A Good Grade 3 Door Contact.
kensplace
Guest anguscanplay
Mine are elmdenes also, but brown in colour, exactly the same instruction sheet, and packaging though.
Slight difference in model no, mine is 6sl-bn-gn 1k0/1k0 eol resistors.
Wired up blue/red shorted together, black and yellow for test readings giving 1k/2k readings depending if reed open or closed.
Is that correct?
Not fitted to door frame yet, but held against a cupboard door for example and tested for immunity they failed....
Maybe the extra thickness of a door frame will do the trick, only way would be to give it a try later on. But I figured immune should mean immune....
do they go open circuit if the magnets too near ?
Nope it can be touching and it wont go open circuit or change state..
just to add, it can go open if certain ways, but not all, ie the way I tested first, it didnt. Other tests can make it go open.
Guest anguscanplay
new ones do - I couldnt get on with them.
Guest anguscanplay
new elmdenes dont gus
new ones do ........... well new as in just last week
Guest anguscanplay
the ones we have dont. Manufactured date?
I`ll have a look after me tea, if it stops raining
