TechEnthusiast Posted September 29, 2008 Posted September 29, 2008 If a Scantronic 9651 is not connected to a monitoring system/service what function do the PA, Fire Alarm, Medical Assistance dual-keys serve? Will they emit an alarm? Can they be reset as normal (i.e. with the user code) or does it require advanced resetting (i.e. by an engineer or remotely)? Any advice will be much appreciated...
hpotter Posted September 29, 2008 Posted September 29, 2008 Yes cmd 87 enables. Sounders & comms are triggered and user code resets. (eng code wont though!)
TechEnthusiast Posted September 29, 2008 Author Posted September 29, 2008 Yes cmd 87 enables. Sounders & comms are triggered and user code resets. (eng code wont though!) Do all dual-key alarms have the same effect? I do not have Comms.
hpotter Posted September 30, 2008 Posted September 30, 2008 Do all dual-key alarms have the same effect?I do not have Comms. Fire & pa give bells & comms (fire different sound to pa). Medical only gives comms and you need to prog it. I guess you could use a comms output to drive a small relay (to give sound etc). Would suggest op8 (normally tech alarm) Cmd 158, option 16.
