Wiring Intellisesne Is215t Pir To Galaxy G2 44
mjs786
hi, i need help to wire a Intellisesne is 215t to my galaxy g2 44. i recently moved house and removed the alarm from my old house, now trying to istall it back, but cant remember how i took the wires off, the terminals on pir are as follows: +, -, c, n/c, t, t. Thanks
you need the eol resistors. If you look its detailed in the early pages of the panel manual
i have no manual, thats why im asking for advice, thanks
ah
you will need a manual mate for one of these, but you need to wire 2 x 1k resistors (if programmed to 1k's) one accross the alarm pair, and on in series with the tamper
basically 1k = closed circuit, 2 k = alarm, oc = tamper, sc = tamper.
There are other posts with wiring diagrams posted if you search.
James
ah
James
thanks James, so 1 of the 1k resistor across c and n/c and other 1k resistor across c and 1 of t, and then 1 wire on empty t, 1 wire on n/c, 1 wire on +, and 1 wire on -. is this correct, if so where would i put these four wires on panel, your help would be much appreciated, thanks.
Sal
the ones across the resistors wire into the zone, the + and - connect to power in the panel. But realistically your gonna continue to strunggle on this panel. Its a serious panel and you will need a manual.
Thanks James your help is much appreiciated.
  • 2 years later...
Hi, I have the engineers manual but I am not certain on this:
On the subject of connecting to the Galaxy panel, I have the G2-44 and just want to check which + and - on the panel do I connect to? There are two power + connections at the botton right below the keypad connections, do I use these for + and if so what do I use for - ?
