Texecom Radioplus Key Fob Programming
sunflare
I have a Texecom Premier 48 v7.6 panel with a fully functional RadioPlus Rx and keyfob TXs.
How can I program the 4th button to trigger an output on the panel to energise a relay to open a newly installed garage door?
:hmm:
Thanks in advance.
Sparky.
The manual says the 4th button is CT1, which I assume to mean Control Timer 1, I would think that if you program the output as Control Timer 1 it will work.
Thanks for the response, I will try that.
