rorton Posted October 2, 2008 Posted October 2, 2008 Sorry for what really seems a dumb question. I am quite a clever chap, but cant get my head around this simple thing... I'll centrally local my alarm panel. I'll position all my accessories (2 x rkp, bell box, mag switch, PIR etc) I run a SINGLE 6 core cable from each accessory back to the panel. Now, i understand i can star, or parallel wire my rkps, just doubling the wires up in the terminals, but i cant get my head around the fact that if i have a PIR on zone 1, and another PIR on Zone 2, and another on Zone 3 and each of them connects to the alarm panel using their black and red wires for alarm (parallel), how to i link the tampers. Im my head im seeing an individual cable going to the PIR, then back out, and into another PIR, which i know isnt the way, so how do i perform the series wiring on the tamper, and does the power series or parallel?? Its using multicore cable where everything isnt star connected which is throwing me, i just cant see it in my head Sorry for the thicko question, but any help appreciated
Guest anguscanplay Posted October 2, 2008 Posted October 2, 2008 Sorry for what really seems a dumb question. I am quite a clever chap, but cant get my head around this simple thing...I'll centrally local my alarm panel. I'll position all my accessories (2 x rkp, bell box, mag switch, PIR etc) I run a SINGLE 6 core cable from each accessory back to the panel. Now, i understand i can star, or parallel wire my rkps, just doubling the wires up in the terminals, but i cant get my head around the fact that if i have a PIR on zone 1, and another PIR on Zone 2, and another on Zone 3 and each of them connects to the alarm panel using their black and red wires for alarm (parallel), how to i link the tampers. Im my head im seeing an individual cable going to the PIR, then back out, and into another PIR, which i know isnt the way, so how do i perform the series wiring on the tamper, and does the power series or parallel?? Its using multicore cable where everything isnt star connected which is throwing me, i just cant see it in my head Sorry for the thicko question, but any help appreciated nah thats exactly how to visualise it for the tamper. for everything else just star
Tilly Posted October 2, 2008 Posted October 2, 2008 When you finish linking the tampers up, you will (should) have two wires left, which should meter out as a dead short... These two wires go into the tamper terminals.
FASTCAR Posted October 2, 2008 Posted October 2, 2008 Now, i understand i can star, or parallel wire my rkps, just doubling the wires up in the terminals You will need to have the RKP tampers in series..(there are seperate tamper terms for the RKPs).
rorton Posted October 3, 2008 Author Posted October 3, 2008 thanks all, so, if i have a single 6 coare from each device back to the central point, i can connect the black/red to the alarm connections on the zones, and the Gree/Yellow for power, but how will i series wire these in the box? Do i just need a terminal block, and connect the others togther? Out of one, into another and so on? And then add the tampers from thr RKP's into this loop as well?
antinode Posted October 3, 2008 Posted October 3, 2008 To series up the tampers (white and blue): Take the blue from the detector on zone 1 and connect it to one of the tamper terminals in the panel. Now take the white from the detector on zone 1 and connect it to the blue from the detector on zone 2. Take the white from the detector on zone 2 and connect it to the blue from the detector on zone 3. Continue this until you end up with one wire left (should be a white one) from the last detector, which will go into the other tamper terminal on the panel. You can put your RKP tampers in this loop in exactly the same way. Trade Member
Guest anguscanplay Posted October 3, 2008 Posted October 3, 2008 To series up the tampers (white and blue):Take the blue from the detector on zone 1 and connect it to one of the tamper terminals in the panel. Now take the white from the detector on zone 1 and connect it to the blue from the detector on zone 2. Take the white from the detector on zone 2 and connect it to the blue from the detector on zone 3. Continue this until you end up with one wire left (should be a white one) from the last detector, which will go into the other tamper terminal on the panel. You can put your RKP tampers in this loop in exactly the same way. or join blue to blue / white to white then you can see at a glance if you`ve missed any detectors out/ crossed circuits and inavertantly shorted the rest out? little tip there for you Anti my man........
mjw Posted October 3, 2008 Posted October 3, 2008 or join blue to blue / white to white then you can see at a glance if you`ve missed any detectors out/ crossed circuits and inavertantly shorted the rest out? would that be series or parrallel then???....lol
Guest anguscanplay Posted October 3, 2008 Posted October 3, 2008 or join blue to blue / white to white then you can see at a glance if you`ve missed any detectors out/ crossed circuits and inavertantly shorted the rest out? would that be series or parrallel then???....lol smart //.B.W.F.// - LOL blue - the paired white - another white - that paired blue - another blue - that paired white -another white .................................etc etc you can see at a glance that the "circle " is complete
antinode Posted October 3, 2008 Posted October 3, 2008 or join blue to blue / white to white then you can see at a glance if you`ve missed any detectors out/ crossed circuits and inavertantly shorted the rest out?little tip there for you Anti my man........ , been a while since I touched a panel with global tampers though to be honest. I have it too easy! Trade Member
