digital-eye Posted October 7, 2008 Share Posted October 7, 2008 Got a customer looking to have some sort of ANPR. Doesnt have to be the logging software but just something that can capture a number plate at night in an industrial estate with street lighting. He has a Geovision capture card in his PC with a dome cam zoomed into a small area but any cat traveling at speed then theres not enough FPS. Any ideas? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/25025-anpr/ Share on other sites More sharing options...
kensplace Posted October 7, 2008 Share Posted October 7, 2008 Best option would be a real anpr camera from the likes of extreme, but they dont come cheap. DIY route you would need to ensure the camera is set to a fast shutter speed, if its to low the plate will probably be blurred/suffer from interlace problems at speed. You may experience problems with headlights etc, real anpr cams usually block visible light and rely on IR illumination I believe. Try a different angle also, maybe higher up for the cam, see if it helps. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/25025-anpr/#findComment-212746 Share on other sites More sharing options...
arfur mo Posted October 7, 2008 Share Posted October 7, 2008 if possible, depending how the camera is setup (as above) you can get fair results if you slow the vehicles down to a crawl with traffic humps, electric barrier even if it simply lifts on approach after a short delay or a chicane etc. regs alan If you think education is difficult, try being stupid!!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/25025-anpr/#findComment-212747 Share on other sites More sharing options...
digital-eye Posted October 7, 2008 Author Share Posted October 7, 2008 Im going to upgrade the to a standalone DVR probably an Apollo, cos the Geovision keeps freezing. So, any particular camera you could recomend? Its a main road so they cant put in any traffic measures im affraid. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/25025-anpr/#findComment-212748 Share on other sites More sharing options...
camullins Posted October 7, 2008 Share Posted October 7, 2008 Im going to upgrade the to a standalone DVR probably an Apollo, cos the Geovision keeps freezing. So, any particular camera you could recomend? Its a main road so they cant put in any traffic measures im affraid. If it's a main road should they really be Using ANPR??? I have setup a simlar system myself. I used a Vista VPC420 with IR lighting. I had a gate with the camera mounted about 1mtr from the floor on the R/H side which gave the best results. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/25025-anpr/#findComment-212753 Share on other sites More sharing options...
james.wilson Posted October 7, 2008 Share Posted October 7, 2008 its not the fps that are the problem, its the shutter speed on the cam doing the capturing. There are tables that tell you what shutter speed to use at a particular vehcile speed but for 40 or below you need 1/250 - 1/ 500. Just use a decent cam that allows shutter speed increases. This wont help low light plates but will solve your vehicle speed problem, but for a general purpose plate grabber look at the derwent reg cams securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/25025-anpr/#findComment-212807 Share on other sites More sharing options...
digital-eye Posted October 7, 2008 Author Share Posted October 7, 2008 OH, excellent guys thanks! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/25025-anpr/#findComment-212814 Share on other sites More sharing options...
NitroN Posted October 8, 2008 Share Posted October 8, 2008 I had a similar situation, but on a slower road, so I'm not sure it will work for you. I used a Samsung 2305 Camera. Initially I had problems because I was using an aspherical lens, which was letting in too much light and the number plates were blurred. I changed the lense to a normal one and hey presto - a perfect number plate picture (from the front - with full headlights) Its not the DVR that you should be concerned about initially, its the camera and the lense. I suggest that you use a camera with wide dynamic range... Perhaps you should also try to capture the rear number plate. NN Link to comment https://www.thesecurityinstaller.co.uk/community/topic/25025-anpr/#findComment-212815 Share on other sites More sharing options...
satsuma01 Posted October 8, 2008 Share Posted October 8, 2008 its not the fps that are the problem, its the shutter speed on the cam doing the capturing. There are tables that tell you what shutter speed to use at a particular vehcile speed but for 40 or below you need 1/250 - 1/ 500. Just use a decent cam that allows shutter speed increases.This wont help low light plates but will solve your vehicle speed problem, but for a general purpose plate grabber look at the derwent reg cams redbull have you any links to the table you mentioned above. "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/25025-anpr/#findComment-212818 Share on other sites More sharing options...
Alpat Systems Posted October 8, 2008 Share Posted October 8, 2008 When a customer asks for ANPR, we usually suggest using a dedicated system. However we have succesfully used Samsung SHC-735 and SDN-550 with IR lighting (there's more to it though than simply choosing a camera and lens!!) Have a read on this thread...... http://www.thesecurityinstaller.co.uk/comm...mp;#entry163109 ......and these website's http://www.licenseplaterecognition.com/ http://www.cctv-information.co.uk/constant3/anpr.html ....and if you decide to go with a dedicated ANPR here's some to consider http://www.derwentcctv.com/home/index.php?...5&show=true http://www.vista-cctv.com/vnpr.htm http://cbceurope.co.uk/CCTV/prodimages/RSC_Kits.pdf http://www.appian-tech.com/products/anpr-cameras/stinger http://www.dedicatedmicros.com/uk/netvu.php http://www.genetec.com/english/solutions/a...u/overview.aspx http://www.geovision.com.tw/english/3_1.as...pgid&pno=28 http://www.security.honeywell.com/uk/video...npr/168975.html ....and a bit more info The size of a UK license plate on cars and commercial vehicles is approximately 510mm long x 110mm high. Motorcycles are different being approximately 255 x 200. However more significantly, the minimum height of the letters must be 79mm. The current UK font is Charles Wright, although there are some illegal formats seen. The size of the number plate and the actual characters will need to be of a certain size when seen by the camera for the OCR software to function. One line of thought is that the number plate should be 18% of the scene width; I prefer to consider the vertical height of the characters, which from previous research should be 3% minimum for a 400 line camera. This in fact equates very closely to the 18% screen width but is more logical when considering different shapes of number plates. (For instance when a car plate is 18% of the screen a motorcycle plate would only be 7 %.) Also note that motorcycles currently do not have to carry a front number plate, but this could change in the future. This provides the first convenient way to calculate the lens angle. For 79mm high characters the scene height needs to be 2633mm. (79 being 3% of 2633). Therefore using a scene height of 2.633M and the known distance, it is a simple matter to calculate the lens angle and thus the focal length. At this stage the height of the camera has not been considered but would not make much difference for normal combinations of distance and camera heights. For an accurate and simple method use the LensCalc software and the top half of table below. The following table shows the lens angle for various distances and a scene height of 2.633M Distance to target 5M 10 15 20 25 30 35 40 45 50 Lens angle 29.5 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/25025-anpr/#findComment-212822 Share on other sites More sharing options...
