Simple Panel For Old Lady (using Simple Prox Rdr)
Matt Ward
Guest anguscanplay
  redbull said:
yep
LOL, its a serious point though. i would say EVERY SINGLE site we`ve upgraded has had a least one or more times when the systems not been set due to
<<< CAN`T SET CHECK >>>
been ignored.
been ignored.
tbh Gus,
one of the biggest reasons i'm not over keen on the wholesale use of external setting devices, fobs, radio butons or ET's, should be 'horses for coarses' allowing the engineer to design with the best insight for that client imo.
your not allowed to observe th keypad from outside, but this loses sight of many keyholders, especially technophobes, sight impaired and the elderly who easily get out of synch with any sort of system when it don't do what it usually does.
imo the best idea for this job (from what has been said by the o/p) would be a CPX/490 with either the earlier keypad having a quickset key, or the using the 4 wire G595/G800 keypads having the prox built in.
set if up for auto pert set 1 if the front door is not openned (what i call au-pair set) and job done.
are there any other panels (outside of gardtecs) which the auto part set feature anyone know of?
regs
alan
Guest anguscanplay
  arfur mo said:
tbh Gus,
regs
alan
I`m generally on about signalled systems - auto part set no good. I explain how strobe confirm is the ONLY way they can be sure the alarms set but its such a sea change from what went before its like trying to wean you off using a neon.
:lol: neons are like my socks - i have a pair for each day of the week - and twice on sundays :rolleyes:
i was discussing in the context of this post being a simple system for an elderly sperson to use (coud flogg him mine :unsure: )
so i think ARC is not an issue, all i know is i've spent many years training keyhoders to look at the alarm display before setting and after unsetting - but the current 'vogue' imo encourages 'set and hope' type of proceedures.
regs
alan
Risco wireless sounders constantly ring, that factory default, i programme them for ten minutes, the batteries (when new) will last for over 6 hours of ringing.
Wisdom wireless keypads are c##p with a capital C.
The wisdom is a sound panel, but i wouldnt wait for the agility cuz gods knows how many years it will take them to finally release it.
The amount of times the local branch kept banging on about the new agility, are you coming in again to see it, we have an open day the agility is on show, but no ones knows when its coming out or at what cost.
hi Adi,
you dislike the wisdom radio wireless keypad i wondered why?
i got a wisdom kit on the workbench for assement at the moment, set it up today all seems fairly robust and works as required. do the remotes bust or fall over or is it just the looks you don't like?
i'd appreceate your comments from youe exoperience, as if it's a 'pup' i don't want to fit it :unsure:
regs
alan
