steve8989 Posted October 8, 2008 Posted October 8, 2008 Has Any one tried Skype on Blackberries? I found mine to be a bit slow?? Any ideas? Steven :!:
Gopher Posted October 9, 2008 Posted October 9, 2008 What do you mean by slow, the software slower than you'd expected? It also depends on what "network" your transferring the data over how quick it will go and the software speed depends on how it's been implimented as well i.e is it running using a java implimentation or is it running on windows, this affects the speed of the software. I use it on my main pc and it's fast enough but then again that is in to broadband and it's a fairly fast PC. Intruder / CCTV / Access Control Technical Support Personal Subscriber to the "K.I.S.S" principle, that's Keep It Simple Stupid, are you?
steve8989 Posted October 9, 2008 Author Posted October 9, 2008 What do you mean by slow, the software slower than you'd expected? It also depends on what "network" your transferring the data over how quick it will go and the software speed depends on how it's been implimented as well i.e is it running using a java implimentation or is it running on windows, this affects the speed of the software.I use it on my main pc and it's fast enough but then again that is in to broadband and it's a fairly fast PC. No I meant I run Skype on my phone (blackberry 8310) the program is called iscoot but I dont know if its suppose to run so slow. I run on GPRS so I know that can be a bit slugish. Any ideas?
james.wilson Posted October 9, 2008 Posted October 9, 2008 id say gprs is too slow for voip, gprs is similar in speed to old modems, ie 56k, edge will help, but id say voip was a 3g only affair securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Gopher Posted October 10, 2008 Posted October 10, 2008 id say gprs is too slow for voip, gprs is similar in speed to old modems, ie 56k, edge will help, but id say voip was a 3g only affair Yeah I believe Skype VoIP needs a 64kbit data channel to work effectivly, sure it tells you somewhere on the main site what the bandwidth requirements are. Intruder / CCTV / Access Control Technical Support Personal Subscriber to the "K.I.S.S" principle, that's Keep It Simple Stupid, are you?
