964RS Posted October 15, 2008 Posted October 15, 2008 Hi new here and after some help. We moved into a new house in 2004 and have a veritas alarm system and panels. System has worked fine but now won't let us set. The 'unset' green light is just flasing repeatedly and we can not set the system. I have downloaded the Veritas 8 user manual (we don't have one for our and not sure which version it is but this has all the same programing formulas it seems) and tried to reset as if it was due to power cut. It goes through coding correctly with correct light sequences etc and even to the set bit but then when we put code in returns to flashing green unset again. Can anyone help????
shinfieldmonkey Posted October 15, 2008 Posted October 15, 2008 sounds like a ac power problen and running on battery back up Mark Terry A.M.I. Security Covering the Thames Valley Tel. 01189 775173 24hours mark.terry@amisecurity.co.uk
Chorlton Posted October 15, 2008 Posted October 15, 2008 BEFORE doing anything be 100% sure you know basic electrical safety , know what I'm refering to, know how to check & have a suitable tool/meter! check the fuse at the supply board check the mains fuse in the panel check the fuse on the circuit board check the 12v battery is good (if it is but is more than 4 years old change it anyway) report back on the double, lol C.
shinfieldmonkey Posted October 15, 2008 Posted October 15, 2008 rememder 240vac will hurt you if you don't know what your doing. if not sure get a pro in Mark Terry A.M.I. Security Covering the Thames Valley Tel. 01189 775173 24hours mark.terry@amisecurity.co.uk
964RS Posted October 15, 2008 Author Posted October 15, 2008 Ok thanks all - will do some checks and report back otherwise any suggestions for reputable repairers to look at it in Nottingham area? update: ok switched power off at main alarm box, changed fuse. switched back on and green power light on but not flashing. chimes start, put in code, green power light flashing again further update: All the clear fuses inside the circuit board box look ok, no broken wires. If battery has gone would that effect useage under normal power though?
Chorlton Posted October 15, 2008 Posted October 15, 2008 1st point - http://www.thesecurityinstaller.co.uk/comm...p?showforum=268 OK great one fuse but what about the others & the battery as per my previous post ? C.
964RS Posted October 15, 2008 Author Posted October 15, 2008 Chorlton - think checking that fuse and visual inspections is about my limit! Probably need to get someone with suitable meter and electrical knowledge to sort....I've no doubt its a power issue now though.
Chorlton Posted October 15, 2008 Posted October 15, 2008 no worries if you don't want to open the panel and poke around. better to leave it if your unsure rather than zap yourself or something inside the panel. hope you get it sorted via someone listed in your area. . C.
breff Posted October 15, 2008 Posted October 15, 2008 Disconnect the battery. Flat battery or mains fail causes the unset light to constantly flash The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
964RS Posted October 16, 2008 Author Posted October 16, 2008 Disconnect the battery.Flat battery or mains fail causes the unset light to constantly flash breff will give that a try....have a feeling it will be the battery in some way as everything else looks ok
