Ade Optima Compact Gen 4 Wiring Help
dewaltdave
Hello Everyone,
Rather Bravely / Stupidly I offered my assistance to a friend of mine in installing the mentioned alarm system to his garage.
Now, Im not an alarm installer, specialist or anything of the sort, but Im not too stupid and give most things a bash. My previous alarm knowledge comes from designing and assisting in the installation of my own Galaxy 512 Panel.
I have phoned Honeywell/ADE for some assistance, but because I am a DIY'er and not a company, they refused to help me at all.
So I come asking for help . . .
Im using an Elmdene Roller shutter contact (RED 4K7/2K2) and a Pyronix KX15DT Selectable EOL PIR as the only 2 zones and have installed the EXT Sounder already.
My problem is that according to the info I have found ADE Panels use 4K7/2K2 but Honeywell use 1k/2k. Im getting kinda lost with the wiring of the roller shutter contact (ie what cables to use - its 6 core pre wired) and not too sure on values for the EOL on PIR.
I cant seem to find anything in the instructions on adding in resistors or resistance values.
I hope this makes sense to somebody who can help me! It would be much appreciated.
Many thanks,
Dave.
Accenta/optima panels dont use resistors at all. They're just closed loop, i.e. short circuit (few ohms) = ok, open circuit (infinite ohms) = alarm.
I was hoping that would be the case.
So I take it I dont put any headers on the EOL in the PIR then, to make it simple circuit.
Quite right, keep it a simple closed cct loop. (resistors = fully supervised).
You will need to change the roller for one like this
http://www.securitywarehouse.co.uk/catalog...products_id=177
Great, thanks.
No way of changing the roller - even by cutting, clipping or otherwise altering to make it CCT
If I wire Pir like this after removing EOLs on PIR and use 4 wires it shoud work right ? assmuing red/blk are +/-ve and yellow/grn are to zone on panel.
+ve | -ve | ALM | ALM | TAM | TAM
red blk yell linked grn
Guest anguscanplay
most graded contacts have an old fashioned alarm pair in there somewhere.
yeah im pretty sure the elmdene has a clean pair, you will just need to find em with a meter.
Ok i have a meter but i'm not sure what i'm looking for on the meter. I take it i'm not looking for any resistance change, just an open and closed circuit to trigger the panel. This should then be a two wire install if i'm getting the grasp of things.
Yes, you are looking for a dead short (well less than 1 ohm) when contact is closed and infinite resistance when the contact is open, just like a light switch!
