Ade Optima Compact Gen 4 Wiring Help
dewaltdave
ok i've got my meter out but i can't seem to find the illusive clean pair. I can get 6.8kohm with the contact closed and 0ohm with it open. It's the widest range of resistance i could find that differ when the contact changes but i think they need to be the other way round. Does that make sense?
think i found it
0.03 ohm contact closed
Infinite ohm contact open
When i say infinite, its the same reading as when i don't touch the two meter leads together. That should do it shouldn't it?
It's red and black for reference.
  • 4 weeks later...
So it's been a while since the last post, its all wired up and the circuits open and close like a gem. Perfect.
But . . .
when i attemp to change anything, like setting EE zone or change timings, strobe confirm on set etc it doesnt seem to save any changes? both zones (door & pir) are coming on as immediate intruder but i want the door to be EE with time delay? Any suggestions?.
absolutely brand spankin'
i have the manual but i think im getting lost in the programing part of things.
If I were to "spec" the system requirements, could someone write me an step by step guide to code it up i.e prog 1, 2 set etc?
Its only a 2 zone simple setup.
TIA
The default factory set -up should do you.
zone 1 e/e ...use for the door
zone 2 inhibit...use for p.i.r.
you wont need prog 2 / 3.
