Fire Hazard?
hpotter
I'm no electrician so bare with me, how did it get from "fibre glass" to "foam", can't see the connection?
Ive seen polystyrene literally bonded to pvc cable as they gel together but didnt think foam was an issue. So did some research below (15mins worth tbo) and found conflicting views.
The heat generation issues (ie from lights & cable plus inability to dissipate same) are different to the chemical reaction problems that have been raised, but given the areas where most likely to happen in a residence (ie loft) I can see a need to look at both issues.
Ive been looking into trade associations for insulation industry and hey ho what they say aint what you get. I'll continue to look before posting.
http://voltimum.co.uk/news/9230/infopro.pr...nsulation-.html
10.1.1.1.pdf
They are both insulation used if lofts!!!
There is some confusion about weather or not polyurethane foam attacks cables but until it's written in stone I treat it the same as polystyrene.
http://www.generalcable.com.au/Technical/10.1.1.1.pdf
My Amateur Radio Forum
Well, I say hats off to hpotter for spotting this problem.
I've sent an enquiry to the National Insulation Association, asking if they and their members are aware of the issue. I'll let you know if I get a reply
I got a very curt reply:
All such issues are considered and technicians trained in such areas. Thank you for registering your concern,
John C Mason
Head of Policy and Communications
01525 383313
Mob: 07917 100237
Visit our website for further information at www.nationalinsulationassociation.org.uk
I guess that means, "sod off"
