BestGear Posted October 20, 2008 Posted October 20, 2008 Guys I just wondered if any of you have written your own code to run on the comIp module? I am writing some code to integrate the Premier range into Homeseer (home automation) - currently using serial port but the protocol is the same over comIp so will support that too. I do like the idea of writing code for the comIP module, to increase the basic functionality. I just need to find a cheap source for the comIP module (unless someone has one lying around...) as
BestGear Posted November 2, 2008 Author Posted November 2, 2008 Guys Just thought I'd give an update. I have parked the comIP connectivity to Homeseer for now, but have integration now written and working into Homeseer using the Crestron and Texecom's own protocol and working well! The only dissapointment for me was that the "Texecom" protocol seems to have had several revisions, and depending on the firmware version of the panel, the protocol feature list is not consistant. All in, I must thank texecom support for their development help - top guys. Anyone on here use Homeseer? David
