Multimeter Calibration
Does anyone know if there is a multimeter I can get that can be caliberated using software on a pc?
And how will you calibrate your PC??
It's just something I have overheard. Cause I see your point though. Think I might have misunderstood something at the time.
you would still need a calibrated meter to check the outputs first.
This is one of those silver/gold issues.
Golds have to have meters calibrated, ssaib and silver can 'demonstate accuracy'
one for angus i think but IMO only way you can do that is with a acalibrated meter. You can just have one calibrated and have a rig like above and calibrate the rest to the one master meter though
Why is it a "Silver /Gold issue" ?
We are silver and have to have calibrated instruments....
he Gold bit just means you have ISO 9000 Quality Management as well......
sorry esp
What i was meaning is the wording between silver and gold is different.
Im sure i have had this discussion before as if i recall the ssaib say that you dont need to calibrate.
Silver 'have to demonstrate accuracy' and gold have to calibrate each meter.
Now how you can demonstrate accuracy without calibrating i have no idea.
sorry esp
Surely if you connect both a known accurate calibrated meter and the one you want to prove to the same potential, such as a variable PSU / resistor etc. and they both read the same at a number of voltages, in all ranges.
Do it weekly, monthly or whatever, using the same calibrated meter, record it in a book, you have demonstrated accuracy.
NACOSS were happy with that a few years ago when we did it.
