Bt Sms Text Service
Amber
I have a Cooper SD2+ connected to a system and working fine using the O2 SMS centre.
I have been asked to switch this to using the BT Text service so that use can be made of the bundled free texts with the BT phone line. Not an unreasonable request.
The problem is that I have tried almost every setting to get this unit to work with BT Text and have even had a BT engineering helping but to no avail. (message centre number 1470 P 17094009)
Even the BT engineer could not confirm the correct settings as apartently the BT SMS gateway is run for them by Unisys.
Has anyone else found this to be a problem or managed to solve it? If so could you post the settings and procedure.
Thanks
I know of the problem ...... but I don't think there is a solution. The texts have to go through a Vodaphone or O2 centre, and can only be directed to mobiles ..... not landlines.
