Omega Posted October 23, 2008 Share Posted October 23, 2008 Hi all I have just left a national security company and intend to set up my own company. When installing for this company, the responsibility for the fused spur lay with the customer. They would often employ an electrician to deal. Whilst I am capable of running a fused spur ( in domestic premises) what are the legalities now that part 'P' is involved? Thanks Link to comment Share on other sites More sharing options...
james.wilson Posted October 23, 2008 Share Posted October 23, 2008 if the work your doing comes under the scope then you either need to be a registered install that can self cert or call in building control to inspect what you do. Or get someone else to do it. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
shinfieldmonkey Posted October 23, 2008 Share Posted October 23, 2008 part p only applies to domestic premises the stipulation is that a person is compitant to do the job. i've just started up on my own and decided to do the one day course at tavcom which i would recomend as its worth brushing up on the readings and paperwork involved. Mark Terry A.M.I. Security Covering the Thames Valley Tel. 01189 775173 24hours mark.terry@amisecurity.co.uk Link to comment Share on other sites More sharing options...
kka Posted October 23, 2008 Share Posted October 23, 2008 Tavcom, i did that one, well worth the time and money. taugh by a guy with thirty years exp in the industry. i would also recommend it. Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114 Link to comment Share on other sites More sharing options...
Omega Posted October 23, 2008 Author Share Posted October 23, 2008 Thanks for the replies After reading these, I Tavcom and ACT who also run a course. Either way I will attend one of these. Thanks for your help! Link to comment Share on other sites More sharing options...
davetherave69 Posted October 23, 2008 Share Posted October 23, 2008 Thanks for the repliesAfter reading these, I Tavcom and ACT who also run a course. Either way I will attend one of these. Thanks for your help! If you run new circuits from the fuse board or in the kitchen for the feed you will have to notify it to building control join the niceic or eca and you can certify your own work Link to comment Share on other sites More sharing options...
Adi Posted October 23, 2008 Share Posted October 23, 2008 AS above, provided it is not a new circuit or in a special location or kitchen then your ok. As always an electrical test certificate should be issued and the person should be competant, so one of the courses you mentioned should be enough. I really can't be ar**** with it anymore. Link to comment Share on other sites More sharing options...
Omega Posted November 11, 2008 Author Share Posted November 11, 2008 Just to finish off this topic. I read the whitepaper from the office of the Deputy Prime Minister. The main criteria is that I can provide a Fused Spur, Additional Socket (except in a bathroom or Kitchen) without the requirement to issue a certificate or requiring a visit from the local Council. Regards Link to comment Share on other sites More sharing options...
Hooner Posted November 11, 2008 Share Posted November 11, 2008 Just to finish off this topic. I read the whitepaper from the office of the Deputy Prime Minister.The main criteria is that I can provide a Fused Spur, Additional Socket (except in a bathroom or Kitchen) without the requirement to issue a certificate or requiring a visit from the local Council. Regards I think you might find thats a bit out of date. If you're fitting a fused spur, additional socket, replacing a light switch, etc, you will need to provide a certificate of minor works. For this you will need the applicable, calbrated test equipment and to have passed the set of exams as part of the defined scope scheme. Once you have your part P card you can submit your certificates to building control direct (bit expensive) or join an approved body such as corgi, nic or AN Other who will submit on your behalf for a nominal fee. ________ Link to comment Share on other sites More sharing options...
james.wilson Posted November 12, 2008 Share Posted November 12, 2008 Also Part P and minor works certs are not related, ie you should of being doing minor works certs even before part p existed securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
