sweetlyred Posted October 28, 2008 Posted October 28, 2008 I have a Scantronic r+ wireless alarm. Several weeks ago the low battery alarm started to sound. I replaced the main battery using the users code to silence the tamper alarm. After replacing the main battery I pressed reset. As this did not cure the alarm indication I thought that the Battery, although new could be at fault, so I replaced it. I have now replaced this battery three times without clearing the indication, and the low battery sounder and light is lit. Any assistance gratefully received.
lawandorder Posted October 28, 2008 Posted October 28, 2008 I have a Scantronic r+ wireless alarm. Several weeks ago the low battery alarm started to sound. I replaced the main battery using the users code to silence the tamper alarm. After replacing the main battery I pressed reset. As this did not cure the alarm indication I thought that the Battery, although new could be at fault, so I replaced it. I have now replaced this battery three times without clearing the indication, and the low battery sounder and light is lit. Any assistance gratefully received. I'm going from memory here and I don't have a 500r manual to hand but are you sure that the low battery light refers to the panel battery? I suspect it refers to one of the detector batteries, have you tried changing the batteries in any detection devices?
j.paul Posted October 28, 2008 Posted October 28, 2008 I have a Scantronic r+ wireless alarm. Several weeks ago the low battery alarm started to sound. I replaced the main battery using the users code to silence the tamper alarm. After replacing the main battery I pressed reset. As this did not cure the alarm indication I thought that the Battery, although new could be at fault, so I replaced it. I have now replaced this battery three times without clearing the indication, and the low battery sounder and light is lit. Any assistance gratefully received. If there is no zone LED showing, then its more likely to be one of the Keyfob (Remote setting device) batteries.. There are no stupid questions, but there are a LOT of inquisitive idiots.
masterblast Posted November 19, 2008 Posted November 19, 2008 Have you checked that the battery charging fuse hasnt blown or that the battery leads are o.k? Failing that i would change the batteries in all your pirs, door contacts etc
Alarm Co Posted November 20, 2008 Posted November 20, 2008 if a zone pir battery is running low that zones light will come on with low battery light ,, if the phob or keypad is running low the pa light with low battery will come on both with the audible alarm you have had if you have had this happen even on one zone i would recomend you go round and change every battery in every pir and keypad assuming it is over 12 - 18 months old?? and always put good quality battery in
sweetlyred Posted December 1, 2008 Author Posted December 1, 2008 I'm going from memory here and I don't have a 500r manual to hand but are you sure that the low battery light refers to the panel battery?I suspect it refers to one of the detector batteries, have you tried changing the batteries in any detection devices?
