SteveOh Posted October 29, 2008 Posted October 29, 2008 Hi fellas. I finally got around to installing the suggested Texecom Premier 24 in my house. All has gone well until I have programmed it. Now when I go to part set the system (on the landing using a LCD keypad) I am given the options Evening Arm Bedtime 1 Arm Bedtime 2 Arm But I can find any mention of this in the manual I have... I am obviously missing something silly here I think... Also, When I set the entry exit and rear door to chime..... it never seems to stick.... and I have to enable chimes again... and again... and again..... Any ideas? S
breff Posted October 29, 2008 Posted October 29, 2008 Evening arm=part set1 bedtime1= partset2 bedtime2=partset3 To enable chime press chime once, to disable press again. make sure that the zone is programmed for chime The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
aptsys Posted November 3, 2008 Posted November 3, 2008 The default setting is for chime to be disabled after the alarm has been set/unset. You have to use the "Auto Chime (Custom Output 2A)" and then set up custom output 2 to operate how you want (permanently enabled, enabled only while unset etc...)
