Set new code on Veritas 8 system
Guest civilian
Guest civilian
Hi,
We have a Veritas 8 system and would like to change the code. We follow the instructions in the user guide (downloaded from Texecom) but the procedure does not seem to work.
The procedures asks us to do the following...
"Enter your existing 4 digit code ****. The Unset light will flash.
Press PROG. All the zone lights will illuminate. Enter 60. All the zone
lights will turn off. Enter your new 4 digit code ****. Zone lights 1,
2, 3 and 4 will illuminate in turn as each digit of the new code is entered.
Press PROG. The system will chime to confirm the new code has been
accepted and all the zone lights will illuminate. Press RESET. The
system will return to unset and all the zone lights will turn off."
The problem is that after entering our old code then pressing PROG, no zone lights illuminate and the panel just beeps (the beep is a low tone).
Any ideas?
Thanks.
Guest Stewart
If it is an early model press
Existing Code
00
01
new code
Prog
Reset
Reset
If it is a new typr
Existing Code
Prog
60
New Code
Prog
Reset
Reset
