Camera's With Integrated Ir Lighting
ZodiacSecurity
It's an unfortunate fact that some manufacturers like to build all singing cameras, although if the truth be told, the vast majority are seriously out of tune.
As redbull correctly suggests, using separate IR illuminators to produce optimised images will always be the preferred option, amongst those who know what they are doing ;)
Have to agree as well, interally those with inbuilt IR are good but outdoors anything pasted maybe 5m, usually less forget it..
Even with additional IR lighting there is a limit to how far you can see anyway depending on what type of IR light you put up - spot or flood type.
Seperate IR
but if it has to be built in try Basson as theyre built in IR cams are quite good but not cheap
