Texecom Speech Dialler Tsd
b14bee
HI I HAVE A INTELLISENSE 800L CONTROL PANEL AND WANT TO FIT A SPEECH DIALLER THE TEXECOM TSD WITH REMOTE MICROPHONE UNIT
MY CONTROL HAS NO NEGATIVE OUT PUT TO TRIGGER A SPEECH DIALLER
I HAVE CONTACTED TEXECOM THEY SAY THAT THERE UNIT NEEDS A NEGATIVE TRIGGER TO MAKE THIS WORK WITH MY CONTROL PANEL YOU WILL NEED TO FIT A RELAY FROM THE BELL POSITIVE TO CONVERT THIS TO A NEGATIVE TRIGGER
CAN ANYONE HELP WITH THIS WHAT TYPE OF RELAY AND HOW TO WIRE IT UP
THANKS
Hello & welcome!
I can't personally help but no doubt other members who can will be along soon enough.
Do us a favour and switch off the "CAPS LOCK" as written it's like "SHOUTING" !!!
cheers,
C.
THANKS
The bell output of the 800l is a switched negative (as is the bell output of almost all panels) so assuming the speech dialler needs a negative trigger you won't need a relay.
The wiring on the pcb is as per the installation manual ST- strobe switched negative
S- sounder switched negative
+ sounder hold off/strobe positive supply
- sounder hold off supply & sounder tamper feed (negative)
-R sounder tamper return (negative)
I have two wires one + and one - what two conections do i make to the control panel 800l for negative switching
You need 3 wires from th dialler to the panle to make it work.
1 Permanent positive
2 Permanent negative
3 Switched negative to trigger.
1&2 would normally be connected to the aux output on the panel though it will work equally well connected to +sounder hold off and - sounder hold off.
3 should be connected to S- in the panel.
I can't tell you where to connect them in the dialler as I haven't fitted a Texecom dialler for a while but it will say in the manual.
