Simple Question On Dsl
Hello,
So, regarding to ADSL standard we can transfer data through 1 pair
(2 threads) at speed of 3,5 Mbps (downspeed) and at maximum distance
of 5,5 kilometres. Am I correct in thinking that through one usual
computer cable (for example, UTP 5e kat. 4x2x0,5 mm
Please explain a bit more about what you hope to do?
The normal way of "sharing" a broadband (DSL) connection is to use a router (or combined modem/router) and they are made by many companies.
I think he wants to use one cable for 3 pairs of signal cables (2x3).
One of the IP CCTV gurus should know if you can do this.
Never heard about 5.5KM though.........that would be a fibre job I think.... ^_^
My Amateur Radio Forum
So, i have made a draft (pdf, attached)
where I explain my problem.
I need several ADSL links due to large
data amount to be transfered.
Besides, I am interesting exactly in DSL
(please, don't offer radiolinks, ISDN,
fibre optics or some other kind of transmission).
Thank you.
Question_on_DSL.pdf
So your not trying to link 2 buildings your wanting to go via the internet?
If so yes you can do it and you will have to calculate your required bandwidth. IP signalling is what your after. For sending CCTV to a monitoring station id advise adpro.
