scotyjohn Posted November 4, 2008 Posted November 4, 2008 The bell box on my alarm set up has the usual coloured lens area at the bottom where the strobe light will flash when the alarm is set off - sounding, what I want to add is a couple off " comfort lights " you know the two red / green whatever alternating lights that will show the alarm to be in operation, something my own alarm does not have. problem is seem to be having problems tracking down anything like this, have looked on ebay and although there are so called dummy alarm lights similar to the above I honestly dont think at just 5mm in size each bulb they will be strong enough to show up, as my particular cover has a blue coloured lens area will I have to obtain blue coloured lights or will any colour still show thru ?? anyone able to possibly suggest a source off these alternating lights that would suit the above job ??
Rulland Posted November 4, 2008 Posted November 4, 2008 You gotta take the cover off to retrofit any supplementary LED's, drilling holes, mounting,wiring etc-why not just change the sounder for want of
SUBS Posted November 4, 2008 Posted November 4, 2008 Sound advice from Rutland, but if you must do it, Maplins have em in different colours with integrated resistors so you can hang em straight on the 12V hold off supply.
Alarm Protection Posted November 4, 2008 Posted November 4, 2008 See these tight Fifers lol!! I would also fit a new bell. Gardtec/Texecom make good ones. Try the Security Warehouse at the top of this page. Pars fan?? !
Guest anguscanplay Posted November 4, 2008 Posted November 4, 2008 . I honestly dont think at just 5mm in size each bulb they will be strong enough to show up, how big do you think the ones you see already working are then? they`ll be 5mm too just buy any you can find, you`ll be fine
camerabloke Posted November 4, 2008 Posted November 4, 2008 The bell box on my alarm set up has the usual coloured lens area at the bottom where the strobe light will flash when the alarm is set off - sounding, what I want to add is a couple off " comfort lights " you know the two red / green whatever alternating lights that will show the alarm to be in operation, something my own alarm does not have.problem is seem to be having problems tracking down anything like this, have looked on ebay and although there are so called dummy alarm lights similar to the above I honestly dont think at just 5mm in size each bulb they will be strong enough to show up, as my particular cover has a blue coloured lens area will I have to obtain blue coloured lights or will any colour still show thru ?? anyone able to possibly suggest a source off these alternating lights that would suit the above job ?? What bell box do you have? Eucam Security Systems 0845 4630 746 www.eucam.co.uk
scotyjohn Posted November 5, 2008 Author Posted November 5, 2008 how big do you think the ones you see already working are then? they`ll be 5mm too just buy any you can find, you`ll be fine Okay for all the comments / info guys. okay ended up going for a Texecom housing with a couple off 5mm leds powered from the self contained lithiam ( spelling ??!! ) battery the came with them. regards the comment above re. 5mm leds being bright enough ?? - funny enough the company who sold me the housing advised me that they would send both red and green coloured leds and see whats best as possibly they wont be strong enough for what I want. just wonder if leds are normally stronger powered if they are actually powered via 12 volt rather than just say the supplied lithiam battery that they come with or is it purely down to the led used ?? p.s comments regards Fife- Pars fan ?? etc - Give me a break !! its only thru marriage I ended up here !!! no seriously must admitt its a great place to stay and a gers man now you ask !!!
hpotter Posted November 5, 2008 Posted November 5, 2008 Okay for all the comments / info guys.okay ended up going for a Texecom housing with a couple off 5mm leds powered from the self contained lithiam ( spelling ??!! ) battery the came with them. regards the comment above re. 5mm leds being bright enough ?? - funny enough the company who sold me the housing advised me that they would send both red and green coloured leds and see whats best as possibly they wont be strong enough for what I want. just wonder if leds are normally stronger powered if they are actually powered via 12 volt rather than just say the supplied lithiam battery that they come with or is it purely down to the led used ?? p.s comments regards Fife- Pars fan ?? etc - Give me a break !! its only thru marriage I ended up here !!! no seriously must admitt its a great place to stay and a gers man now you ask !!! If you powered a std LED via 12v battery it will blow they work on about 1.5v and need a 1K ohm resistor in series. You can get 12v LEDS http://www.maplin.co.uk/module.aspx?moduleno=35782 And you can get bright std LEDs (that will need a resistor) and all sorts http://www.maplin.co.uk/family.aspx?menu=1...Optoelectronics
scotyjohn Posted November 5, 2008 Author Posted November 5, 2008 If you powered a std LED via 12v battery it will blow they work on about 1.5v and need a 1K ohm resistor in series. You can get 12v LEDShttp://www.maplin.co.uk/module.aspx?moduleno=35782 And you can get bright std LEDs (that will need a resistor) and all sorts http://www.maplin.co.uk/family.aspx?menu=1...Optoelectronics Okay thats great appreciatte the info / links, okay regards the 12 volt leds, the 12 volt battery that is within the alarm sounder box, any advice on just what I would require to add to the two pins off LED, can I just wire a +- wire from these points straight to the battery ?? as I say will see how I get on with the new units hopefully they might actually turn out okay ie. strong enough to be viewed from a distance. would still like to know exactly where to buy the actual alternating leds that come fitted to a lot alarm sounders as supplied, surely they can just be purchased seperatly rather than having to so called dummy alarm led lights ??
james.wilson Posted November 5, 2008 Posted November 5, 2008 hang on you keep saying lithium battery etc. Your not using a rechargable nicad out of a sounder to run these are you? If they are to run of a battery they usally run from a d or c cell 1.5v battery and the holder and everything comes complete. If you want to run a normal led of a 12v source (they are usually 5v) then as above you need a current limiting resistor. 1k will do here here but it depends on your load (ie of the led) you could buy the leds seperatly but they wouldnrt be synced. For the sake of a sounder id just buy one fo them. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
