caithalan Posted November 4, 2008 Posted November 4, 2008 Hi I havea gardtec 595 control panel that I quick part set at night before going to bed and it makes a buzz noise- I then get up early and unset it before leaving for work - the control panel is on the other side of the wall from my sons bedroom and the chirping/note that it plays to tell me it is unset wakes him up every day at 5am! Can this chime noise be turned off so it is silent when i turn off the alarm? Hope you can help!! Alan
antinode Posted November 4, 2008 Posted November 4, 2008 The volume can be turned down from engineer mode, but unless you have the code, there is'nt a great deal you can do. Trade Member
Chorlton Posted November 4, 2008 Posted November 4, 2008 get your service company to sort it at the next annual service. If you don't get it serviced annually I'd strongly advise it. For a short term fix try blu-tac, duct tape or bubble gum....no seriously it muffles it. If you prefer i can suggest a local company to service and sort it for a semsible cost. C.
caithalan Posted November 5, 2008 Author Posted November 5, 2008 I assume the engineer code isn't the code I use to set/unset? Can I try that without harming the system?
Gopher Posted November 6, 2008 Posted November 6, 2008 I assume the engineer code isn't the code I use to set/unset? Can I try that without harming the system? Yes engineering code is completly different to the code you use to set/unset the system. Trying it won't let you into the required menu to change the volume, I'd temporarly muffle it as Chorlton suggested and also get a company to come out and check it over.. Intruder / CCTV / Access Control Technical Support Personal Subscriber to the "K.I.S.S" principle, that's Keep It Simple Stupid, are you?
