Cubit Posted November 6, 2008 Posted November 6, 2008 CHECK THE DATA PROTECTION MANUAL IT EXPLAINS ALL THE AREAS OF RECORDINGS GUYS Somehow, i think Ilkie knows a bit about the subject.
ilkie Posted November 6, 2008 Posted November 6, 2008 CHECK THE DATA PROTECTION MANUAL IT EXPLAINS ALL THE AREAS OF RECORDINGS GUYS Be careful with audio, it is a potential minefield I think. The difference between alarm regs and CCTV regs is that contravention of the DPA, RIPA and FOI Act can lead the end user to personal criminal prosecution. Re DPA CoP on audio See............... "CCTV must not be used to record conversations between members of the public as this is highly intrusive and unlikely to be justified. You should choose a system without this facility if possible. If your system comes equipped with a sound recording facility then you should turn this off or disable it in some other way. There are limited circumstances in which audio recording may be justified, subject to sufficient safeguards. These could include: Audio based alert systems (such as those triggered by changes in noise patterns such as sudden shouting). Conversations must not be recorded, and operators should not listen in. Two-way audio feeds from
sjonley Posted November 8, 2008 Posted November 8, 2008 can any one tell me if i have a dvr without audio on board is there any way i can have audio via a amp or type device You'll have to change the dvr to one with audio recording. make sure the one you use has lip sync audio recording otherwise your stuffed. Kind regards Stuart Onley SAMS Consultancy Independent Security Consultants email:enquiries@samsconsultancy.co.uk website:www.samsconsultancy.co.uk
alarmman62 Posted November 10, 2008 Author Posted November 10, 2008 You'll have to change the dvr to one with audio recording. make sure the one you use has lip sync audio recording otherwise your stuffed. thanks for that peice of imformation ilkie i have warned the customer that it will be a end user problem and not mine if they wish to use audio then it on there heads but thanks again for thr usefull help regards andy amb alarms
Chris Sec Posted November 14, 2008 Posted November 14, 2008 upgrading the motherboard on the dvr, could be a very costly upgrade and I doubt it is available to do. I would seriously look at an expansion board (PCI if available) to add audio to the system. Alternatively it looks to me like a new dvr system is the only viable option...
sjonley Posted November 14, 2008 Posted November 14, 2008 upgrading the motherboard on the dvr, could be a very costly upgrade and I doubt it is available to do. I would seriously look at an expansion board (PCI if available) to add audio to the system. Alternatively it looks to me like a new dvr system is the only viable option... This depends on whether the DVR is based on a PC chassis. For an embedded DVR PCI cards are not normally available. Kind regards Stuart Onley SAMS Consultancy Independent Security Consultants email:enquiries@samsconsultancy.co.uk website:www.samsconsultancy.co.uk
alarmman62 Posted November 16, 2008 Author Posted November 16, 2008 i decided to go with the dvr without audio explained to the customer the sensitivity of its functions and she agreed in principle that we shall not have audi however i did manage to persaude her now she has a fully funcional dvr system and is happy with that thanks for the help guys
